1999 Chevy S-10 Gas Tank Removal
KENTOSBORNE
  • 1999 CHEVROLET S-10
  • 4 CYL
  • 127,000 MILES
I would like to know step by step and location of retaining bolts to remove the gas tank for the above vehicle.
Do you
have the same problem?
Wednesday, October 6th, 2010 AT 1:56 PM
WRENCHTECH
  • EXPERT
The tank is held in by 2 straps plus the electrical plug and lines going in.
You might find that it's easier to lift the bed off than pull the tank. That's what I do.
Remove the 4 bolts from the driver's side and loosen the ones on the right side. Remove the screws from the filler and you can tilt the bed toward the passenger side. Just make sure it is supported well before getting under it.
Wednesday, October 6th, 2010 AT 2:33 PM
Recommended Guides
