1998 Chevy S-10 Won't Start`
RIG
  • 1998 CHEVROLET S-10
Engine Mechanical problem
1998 Chevy S-10 4 cyl Two Wheel Drive Manual 100k miles
My S-10 won't Start after my daughter stalled it when I was teaching her to drive stick. I have lights on dash and can push start it. Removed Starter and took it and Battery to A. Zone both tested fine. When I turn the Key there is Nothing there just dash lights.
Do you
have the same problem?
Wednesday, August 27th, 2008 AT 2:56 PM
Check fuse IGN C 20amp and Crank fuse 20amp-if okay disconnect the brake switch at brake pedal bracket and jumper it and try to start. Still no crank-jumper small terminal that has the purple wire to the battery terminal on the starter-did it crank if so-replace the starter relay and check ign A maxi fuse 40amp-Still no crank have the igniton switch tested.
Wednesday, August 27th, 2008 AT 3:14 PM
Recommended Guides
