1997 Chevy S-10 Power auxiliary outlets do not work?
PIGFARMER15
  • 1997 CHEVROLET S-10
Electrical problem
1997 Chevy S-10 6 cyl Two Wheel Drive Automatic
Power auxiliary outlets do not work. Fuse checks good. Also Cigarete lighter does not work
Do you
have the same problem?
Sunday, December 28th, 2008 AT 7:50 PM
M_H_RITZEL
  • EXPERT
Check with a static tester. It is one that light up when you touch a live wire. If you have voltage to the outlet then check the ground.
Tuesday, December 30th, 2008 AT 8:10 AM
Recommended Guides
