1997 Chevy S-10
BACON21
  • 1997 CHEVROLET S-10
Engine Performance problem
1997 Chevy S-10 6 cyl Two Wheel Drive Automatic
where is the fuel pressure regulator located at and the test port?
Do you
have the same problem?
Tuesday, August 10th, 2010 AT 1:38 PM
ANGELM
It's under/inside intake manifold. You have a spider fuel injection system. TEst port should be seeen above intake mainfold behind what appears to be the carb. It will have a screw on cap which covers a shrader valve. Look like a tire air valve. Engine off, cap off, have rag in hand and depress valve - gas should squirt out if any pressure in system. Be careful with your eyes or hot exhaust manifold.
Friday, December 3rd, 2010 AT 4:19 PM
Recommended Guides
