1996 Chevy S-10 Shift down
KYBOB
  • 1996 CHEVROLET S-10
  • 4 CYL
  • 38,500 MILES
When I put it in drive it wont go, can put it in 1st or 2nd and puull out but have to shift up manual, and when it shifts down for passing or at a stop light it seems to go to neutral and have to down shift manual, if I coast down a hill in drive its like neutral till speed comes up then will automaticly into gear 3rd
Do you
have the same problem?
Sunday, March 8th, 2009 AT 10:28 AM
FRANK2009
Is there any humming noses?
First I would check my transmission fluid.
Look to see what color it is also smell of it to see if it has a burn smell. This will help tell u if there mybe something wrong with the transmission.
You also could try changing the transmission filter.
I had a car once that done the samething.
I changed the transmission filter and fixed it.
Hope this has been some help.
Thursday, March 12th, 2009 AT 5:42 AM
Recommended Guides
