1996 Chevy S-10 fuel pump
STLEEGL
  • 1996 CHEVROLET S-10
  • 4 CYL
  • 80,987 MILES
What would cause the fuel pump to run constantly with the key off and the relays under the hood diconnected?
Do you
have the same problem?
Saturday, July 26th, 2008 AT 8:24 PM
SWILLIAMS
Sounds like the oil pressure switch is stuck on. The relay doesn't power the pump full time. The relay and computer power the pump for a few seconds just to build pressure in the system. Once the engine starts it builds oil pressure and that activates a pressure switch. That switch actually powers the pump. It also acts as a safety. No oil pressure and the engine won't run.
Tuesday, July 29th, 2008 AT 9:36 PM
Recommended Guides
