1995 Chevy S-10 Fuel Injection
PAULKILLICK
  • 1995 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 205,000 MILES
I have this S10 Blazer that I replaced the fuel injection spider with one from Kragen. Since then I have had to replace it twice. It jerks and even cuts out and is hard to start. After replacing the spider it runs purfectly for several months then I begin to have problems again. What would cause the fuel injection unit to give up so often, Is it bad parts or some other problem? I have had the fuel pump changed as well as the crank position sensor.
Do you
have the same problem?
Tuesday, April 27th, 2010 AT 10:14 AM
Check the fuel pressure if its 60-66psi KOEO
Tuesday, April 27th, 2010 AT 11:58 AM
Recommended Guides
