1991 Chevy S-10 Starts than dies
DDOG77
  • 1991 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 19,100 MILES
My 1991 S10 pickup will turn over nicely, run for 2-3 seconds than die. If I continue this for 4-5 attempts, the engine will eventually stay idling, while I high rev the throttle. This seems to get the engine warmed up enough that it won't stall and I can back out the driveway and drive off with no probelms while on the road. When I stop again, it fires right up while still hot, but next morning same thing when cold. Fuel pressure is fine, as is pump. Any ideas where to start?
Do you
have the same problem?
Monday, August 17th, 2009 AT 1:13 PM
BILLYMAC
  • EXPERT
Hi sounds like a typical temp sensor prob
Monday, August 17th, 2009 AT 1:20 PM
Recommended Guides
