1991 Chevy S-10 ignition key
MADOGMEDIC
  • 1991 CHEVROLET S-10
  • 6 CYL
  • 60,000 MILES
When I go to turn off the engine, the ignition will not let me turn the key to the "off" position, and the only way I have to turn it off is to pull the high tension lead off of the coil (fun, not).
how can I fix this problem?
There is no key release lever, and I put the transmission into Park.
I really dont want to pull the steering wheel.
Do you
have the same problem?
Thursday, October 15th, 2009 AT 1:55 PM
  • EXPERT
I hate to say it, but the problem is either in the tumbler or the ignition switch at the bottom of the steering column. If I would have to guess, I would say remove the steering wheel (sorry) and access the tumbler. Disconnect it from the shaft that moves the switch and see if it moves freely then. IF it does, the problem is at the other end. If it still doesn't turn properly, the tumbler is bad.
Saturday, October 17th, 2009 AT 4:34 PM
Recommended Guides
