2000 Other Chevrolet Models Starting problems
KINGSMENRJ
  • 2000 CHEVROLET
  • 4 CYL
  • FWD
  • 116,000 MILES
My 2000 chevy prizm will not start. I poured fuel into the throttle body and it starts but dies. The fuel pump is pumping once I remove the line. Could it be the voltage going to the injector? I removed the injectors and tested them and they make contact noises and sprays, but it will only start after the fuel leaks into the injectors after a couple of miniutes.
Not sure what to do.
Thanks
Do you
have the same problem?
Thursday, June 12th, 2008 AT 12:56 PM
RHALL77
Check fuel pressure. Let me no what you find
Thursday, June 12th, 2008 AT 1:05 PM
Recommended Guides
