1974 Chevy Nova Pushrod Adjustment
FR8TRAN
  • 1974 CHEVROLET NOVA
  • V8
  • 20 MILES
My nephew just purchased a Nova with a rebuilt 350 small block. He was told it would need a few adjustments before it was ready for driving.
I found that it needs more than a few adjustments already. This is the problem I am having. One of the rods is tapping and I have tried to adjust to see if that was the problem. I am what some call a backyard tree mechanic. When I worked in a shop they taught me different ways to adjust the rockers for the push rods and yet I have forgotten all I knew.
I have read your reply to an earlier respons and yet I am still a little (OK, a lot stupid) to understanding your answer.
Here is your reply and then my question:
Answer: Remove valve covers, with the valve in the idle position loosen till the push rod is "free" then tighten back down 1/2 turn. Reinstall valve cover recheck.
What do you mean by valve in "Idle" position? Is that where the rod is all the way down or up?
Do you
have the same problem?
Thursday, May 15th, 2008 AT 5:12 PM
PEAR69
Do you have hydraulic lifters or solid lifters?
Monday, May 19th, 2008 AT 4:32 AM
Recommended Guides
