2002 Chevy Monte Carlo SOMETIMES IT STARTS & SOMETIMES
LINDA ODLE
  • 2002 CHEVROLET MONTE CARLO
  • V8
  • 80,000 MILES
STARTER IS OK, NEW IGNITION SWITCH PUT IN
IT HAS BEEN AT A REPAIR SHOP FOR 2 WEEKS AND EVERY TIME THEY GO TO START IT, IT STARTS. SOMEONE SAID MAYBE THE KEY NEEDS FLASHED. THEY SAY THEY CAN'T FIND THE PROBLEM UNLESS IT DOES NOT START. I CAN DRIVE IT TO WORK AND THEN AFTER WORK GO TO START AND IT WON'T. SOMETIMES IF YOU LEAVE THE KEY TURNED ON AND DOOR OPEN FOR 15 MIN. IT MIGHT START. PLEASE HELP!
Do you
have the same problem?
Monday, October 25th, 2010 AT 7:40 AM
WRENCHTECH
  • EXPERT
Is the security light flashing when this happens?
Monday, October 25th, 2010 AT 8:25 AM
Recommended Guides
