Location to recharge A/C?
NYRFAN85
  • 1997 CHEVROLET MONTE CARLO
Air Conditioning problem 6 cyl Automatic
Hi, my '97 Monte Carlo LS recently stopped blowing cold air when the A/C is turned on. I have a can of Freon (or whatever you call it) with a gauge that I can put in to recharge the AC. My question is, where is the opening/plug for this? I need an image and/or a very detailed description of the location, because I can't find it ANYWHERE! I remember when my car had been fixed before, they took something off in order to get to it.
Any help would be GREATLY appreciated, because I need AC!
Friday, July 4th, 2008 AT 3:18 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
Yep its in a weird spot but I found it for you here is a diagram (BELOW) and a guide to ehlp you get the problem fixed.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Cheers, Ken
Friday, May 26th, 2017 AT 6:44 PM
THADCARR
  • 6 CYL
  • 130,000 MILES
Where do I charge the ac in this vehicle 97 monte carlo
Tuesday, June 30th, 2020 AT 1:54 PM (Merged)
Look for the 13mm fitting which is the low side-no see video to find the port
https://youtu.be/ON2dYcmXIAw
LIONELL8732
  • 138 POSTS
  • 1996 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 212,800 MILES
I got a 1996 monte carlo z34 3.4 dohc engine and I want to no were do I put the freon at and whaf kind do I use.
Monday, July 13th, 2020 AT 1:49 PM (Merged)
Charge it at the low side pressure service port and use R134a.
LIONELL8732
  • 138 POSTS
Ok thanks alot and were is the low pressure port located at on my car.
Sorry, I've tried my auto references Mit1 and Alldata no location but the low side is always between the compressor and evaporator which is the suction line.
