2005 Chevy Malibu Power steering
MARYANNDIMATTIA
  • 2005 CHEVROLET MALIBU
  • 4 CYL
  • FWD
  • 45,000 MILES
Power steering light comes on daily in 2005 chev malibu. CanOBD2 test shows nothing. Concerned about 300 mile trip in two days, should I see mechanic before hand?
Do you
have the same problem?
Wednesday, January 7th, 2009 AT 9:11 AM
BRIAN 1
  • EXPERT
I would have it looked at before. You said obd test showed nothing, did the dealer scan it or a local shop?Most scan tools will not come up with an codes in the power steering control module, only a tech 2 will. There is a code in this module. If you don't have this looked at or fixed it could cause you to loose power assist or the steering will shake very badly. If you get the code post it and I will advise from there.
Wednesday, January 7th, 2009 AT 9:35 AM
Recommended Guides
