2001 Chevy Malibu FEUL
ERNIE77
  • 2001 CHEVROLET MALIBU
Electrical problem
2001 Chevy Malibu 6 cyl Two Wheel Drive Automatic
MY 2001 MALIBU RAN OUT OF GAS WHEN I FILLED THE TANK AND TRIED TO RESTART MY CAR IT WOULDNT START AM I DOING SOMETHING WRONG
Do you
have the same problem?
Friday, December 4th, 2009 AT 7:26 PM
BLUELIGHTNIN6
  • EXPERT
You will need to get the air out of the fuel lines. To do this, cycle your ignition key to the ON position (don't crank). Leave it there for 10 seconds then turn it back to OFF. Do this several times then try cranking to start. Also replacement of the fuel filter is recommended since it most likely picked up a lot of contaminents when running out of fuel.
Friday, December 4th, 2009 AT 7:30 PM
Recommended Guides
