2000 Chevy Malibu
KENNETH GIPSON
  • 2000 CHEVROLET MALIBU
Electrical problem
2000 Chevy Malibu 6 cyl Front Wheel Drive Automatic
The temp guage and fuell guage suddenly stopped working. Speedometer and tacheometer still work. Please help me find a solution?
Do you
have the same problem?
Saturday, February 27th, 2010 AT 8:40 PM
BLUELIGHTNIN6
  • EXPERT
Check the A/C BFC fuse. If you replace it and it does not blow again soon after then you're all good. If it does blow as soon as you start engine, unplug the A/C clutch. Need to then check if it is a wiring problem by loading the circuit with a headlight and if it does not blow the fuse then the wiring is OK and the A/C compressor needs replaced. Pretty common for these Malibus.
Saturday, February 27th, 2010 AT 9:31 PM
Recommended Guides
