Transmission dip stick
DEMOND30
  • 2010 CHEVROLET MALIBU
  • 2.4L
  • 4 CYL
  • FWD
  • 107,000 MILES
How can you tell that your transmission level is good on a 2010 Chevy Malibu. I Cant see no fluid now where and plus it doesn't have a dip stick to check it. So how can I tell that my transmission level is good.
Thursday, May 22nd, 2014 AT 6:06 AM
PROTECH1980
  • 901 POSTS
Remove the transmission oil drain plug in the transmission case near the right hand axle seal. It is on the engine side of the seal, below the seal.
2. From on top of the transmission, remove the vent plug assembly.
3. With the engine idling at operating temperature, add transmission fluid through the top hole until it runs out of the bottom hole
Check out the diagram (Below) #65
Saturday, January 7th, 2017 AT 11:36 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, proper steps are below to check your tranny fluid..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1282.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_234.jpg
Saturday, January 7th, 2017 AT 11:37 AM (Merged)
DANIELLEELLERY
  • 1999 CHEVROLET MALIBU
Transmission problem
1999 Chevy Malibu
Cant find a transmission oil dipstick or where to put transmission oil?
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_99_malibu_fluid_plug_1.jpg
There is probably a vent plug on top of transaxle, you add fluid there, if needed.
LALAMURPH
1999 Chevy Malibu 6 cyl Front Wheel Drive Automatic
There is no dipstick so I was just wondering how you know when you put enough transmission fluid in?
DOCFIXIT
  • 18,828 POSTS
GM says good for 100K miles then renew fluid.
LINDASM
  • CHEVROLET MALIBU
Where and how do I add Transmission fuel to my 2000 chevy malibu, I can't find the dipstick?
Thanks Linda? ?
DOCFIXIT
  • 18,828 POSTS
Checkout Bluelightnin6 post has diagram of vent that is removed to add fluid. First car needs to be jacked up level and check plug removed to see if it needs fluid
Saturday, January 7th, 2017 AT 1:23 PM
