Where is the crankshaft position sensor location, if is a diagram please provide. Thanks in advance.
Monday, September 22nd, 2014 AT 6:35 PM
MECHANIC
There are two different locations depending on which engine you have but where is a guide to help you see what you are in for when doing the job with diagrams of how it will be on your car
Cheers
Images (Click to make bigger)
SPONSORED LINKS
Monday, April 8th, 2019 AT 12:44 PM
AUDI SALDANA
MEMBER
1 POST
2009 CHEVROLET MALIBU
84 MILES
I need know where is the crank position censor is located. Cat turns on and works fine it heats up a little but fans turns on cools down. I turn car off and it wont start again for about twenty minutes.
Wednesday, January 27th, 2021 AT 11:04 AM
(Merged)
HMAC300
MECHANIC
It may be a weak fuel pump scan for codes and check fuel pressure when hot and failing to start.
see picture for crank sensor, but get scanned first auto parts does for free.
Image (Click to make bigger)
(Merged)
RENEE L
ADMIN
Hi AUDI,
If you decide to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
Wednesday, January 27th, 2021 AT 11:07 AM
(Merged)
GUITARCAT
MEMBER
1 POST
2004 CHEVROLET MALIBU
4 CYL
FWD
AUTOMATIC
76,778 MILES
Where is the crank sensor on a 2.2 ecotec malibu classic?
(Merged)
MECHANIC
Here is the location for the crank sensor.
Please let us know what you find.
(Merged)
H-TOWN
MEMBER
1 POST
1998 CHEVROLET MALIBU
6 CYL
FWD
AUTOMATIC
168,225 MILES
About how much should the labor be to replace one a camshaft sensor and two replace a crankshaft sensor
Wednesday, January 27th, 2021 AT 11:08 AM
(Merged)
SERVICE WRITER
MECHANIC
According to Mitchell 1, the book time for the camshaft sensor is 1.3 hours.
And the crankshaft sensor is 1.3 for the 24x and.7 for the 7x.
Multiply the hours times the shop rate and you will get an approximate cost. This is a guide only and the cost can vary from shop to shop and any problems incountered will affect the cost.
(Merged)
JACKJESSICA
MEMBER
1 POST
1997 CHEVROLET MALIBU
4 CYL
FWD
AUTOMATIC
150,000 MILES
Where can I find crankshaft sensor for a 97 Chevy Malibu?
SPONSORED LINKS
(Merged)
MECHANIC
Here is a guide to show you what you are in fo when changing it and the location for you car in the diagrams below.
