1997 Chevy Malibu Coolant leak coming from near belt
SESPEAR86
  • 1997 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 210,000 MILES
Just got my car up and running again after it sat for a year. I noticed the low coolant light is always on even when the resevior is full. I kept smelling coolant so I checked the engine. I noticed that the belt was flinging coolant off of it. Upon closer inspection it looked like it was coming from the water pump. I got the pump replaced and i'm still having the same issues. What could be causing the leak? And why does the low coolant light stay on when it appears full.
Do you
have the same problem?
Tuesday, November 9th, 2010 AT 7:04 PM
BMRFIXIT
  • EXPERT
Intake manifold gasket is a very common problem and a cause for coolant lose
also check timing cover gasket
good luck
Friday, November 12th, 2010 AT 12:33 AM
Recommended Guides
