1999 Chevy Lumina 1999 Chevy Lumina Will turn over but will
BIGMOOK
  • 1999 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 115,000 MILES
Car will turn over but will not start gets gas but I am not sur about the fire. The igniton system fuse has a buzz when car is turned on and I replaced the fuel and I does the same thing. Had stater rebuilt but still wont start. I need some help
Do you
have the same problem?
Saturday, May 23rd, 2009 AT 1:38 PM
MMPRINCE4000
  • EXPERT
Check fuel pressure with mechanical gauge, should be above 40psi, ign. On engine not running.
Remove plug. I use a spark tester you can buy at most autoparts stores. Attach wire to tester and it has a clip you attach to ground on head (like valve cover bolt), you are looking for blue snapping spark.
If no spark, check fuses and if necessary, have ign. Module tested at most autoparts stores for free.
Sunday, May 24th, 2009 AT 8:48 AM
Recommended Guides
