1995 Chevy Lumina ENGINE WONT CRANK ON THE FIRST TRY WHILE
BOBBYB927
  • 1995 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 110,000 MILES
I have the chevy lumina mini van. When the vehicale is cold it wont crank when I turn the key. I may have to turn the key 2 or 3 times before the engine will start to crank. But when it starts to crank its slow at first then fires right up.
Do you
have the same problem?
Friday, December 12th, 2008 AT 8:35 PM
Have the ignition switch and starter checked out-
Friday, December 12th, 2008 AT 8:40 PM
Recommended Guides
