Turn signal flasher
CMOATE
  • 1992 CHEVROLET LUMINA
i have a bad turn signal flasher and I can't find it to replace. From what i've been told it supposed to be on the steering column but I can't find it. Is there an alternate location? Or is it hidden behind something?
Sunday, February 15th, 2009 AT 4:40 PM
The turn signal flasher is located behind left side of dash right of the steering column
See the diagram attached below for location
Sunday, February 15th, 2009 AT 6:10 PM
FIXITMR
  • 9,990 POSTS
  • 1990 CHEVROLET LUMINA
  • FWD
  • 125,000 MILES
Where's the turn signal flasher relay on my 90 lumina APV. There's a small fuse box in the glove box but no flasher. Thanks
Wednesday, March 27th, 2019 AT 6:05 PM (Merged)
FIXITMR
  • 9,990 POSTS
Ok, here's what I did. I went out and used turn signals without starting vehicle and listened for location of relay. Drivers side uunder dash left of steering column obscured in a bracket attached to some control module of some sort, having a big metal transistor in a heat sink with a wide multi wired plastic plug. If you pop relay out of bracket it will dangle where it is convenient to get to.
SPAZMOM
  • CHEVROLET LUMINA
Where is the location of the flasher unit in a 1990 Chevrolet Lumina Euro 3.1L for the turn signals. Please.
MIKEYBDMAN
  • 623 POSTS
Looking at the diagram, it looks below and behind the glove box area. Try and look just above the floor to the right of the Assembly Line Diagnostic Connector and not as far as the glove box.
Wish I could be more helpful.
MARYR1977
  • 1997 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 180,000 MILES
How do I fix or replace the lights on my dashboard, and my turn signal lights work when they feel like it along with my emergency flashers. Someone told me that I had to replace the steering wheel column to fix it. When I want to turn left I have to hold down the blinker shaft but not if I want to turn right that one still clicks and holds itself in place.
MEREDITHDAY24
As far as the turn signals, I can tell you that the turn signal switch needs to be replaced. The steering wheel has to come off to replace the switch and you have to have a tool for that.
The dashboard lights can be replaced if needed, I went to replace my dashboard lights and they were fine, so you might want to check the fuse and the main circuit breaker first.
MARKYOES
  • 6 POSTS
  • 2000 CHEVROLET LUMINA
  • 3.1L
  • V6
  • FWD
  • 111,000 MILES
Where is the flasher located for the turn signals
  • 108,164 POSTS
It should be behind the left side of the dash.
MARKYOES
  • 6 POSTS
Thank you, I'll look some more.
  • 108,164 POSTS
Let me know if you find it. If you can't, I will try to find a pic or diagram.
MARKYOES
  • 6 POSTS
Thank you. Yes I found it. When I was looking in the owners manuals it was saying that the 10 amp fuse was the flasher. And I knew that wasn't right.
CRUZJFRANCO
  • 1999 CHEVROLET LUMINA
  • 6 CYL
  • 4WD
  • 50,000 MILES
How to install the signal flasher
REMOVAL PROCEDURE
Remove the LH instrument panel (IP) insulator.
Pull the hazard/turn signal flasher (2) to release the flasher retainer from the dash mat (1).
Disconnect the electrical connector from the flasher.
  • 108,164 POSTS
I hope your problem is fixed. Let me know if you have other questions.
CSMOYER
  • 1994 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 156,100 MILES
My turn signals stopped working, I replaced the bulbs in the taillights, changed the fuse and changed the flasher unit. My 4-ways work, but not the turn signals. I'm baffled at what is the problem. Any help is surely appreciated. Thank you.
Test the turn and hazard switch the turn signal circuit goes thru there before it hits the lights
FREUDDREAM
Electrical problem
1992 Chevy Lumina 6 cyl Front Wheel Drive Automatic
Where are the turn signal fuses located?
DOCFIXIT
  • 18,828 POSTS
In glove box fuse #13
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_312.jpg
Wednesday, March 27th, 2019 AT 6:06 PM (Merged)
MWLEMKE1
  • 6 CYL
  • FWD
  • 89,000 MILES
I have been having trouble with my turn signal, when making a right turn I need to hold the switch up constantly inorder to keep the blinker on or it won't stay on by itself. Recently, I have been having trouble with the left turn signal and have noticed smoke coming from the steering wheel column when signaling. Now the left turn signal won't work at all but at times does flash only once. I got out of the car and noticed the back blinker still stays lit but doesn't flash (I already checked the light bulbs and aren't burned out) I am trying to fiqure out what the problem is and what the cost would be of taking it in to a repair shop to get the car serviced. Any information would greatly be appreciated.
