Firing order?
RHONDA BARA
  • 1997 CHEVROLET LUMINA
Six cylinder two wheel drive automatic 135,000 miles.
Need a diagram for firing order spark plugs.
Monday, July 20th, 2009 AT 2:22 AM
  • 31,938 POSTS
Hi there,
Firing order. See pictures for details.
mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_1_27.jpg
Monday, July 20th, 2009 AT 4:59 AM
TXSLIM
  • 1996 CHEVROLET LUMINA
Engine Performance problem
1996 Chevy Lumina 6 cyl Front Wheel Drive Automatic
firing order and plug wire placement on coils
Monday, January 18th, 2021 AT 8:43 AM (Merged)
  • 108,170 POSTS
Hi:
The following is for a 3.1 and 3.4 is as follows:
1-2-3-4-5-6
cylinder locations.
5 6
3 4
1 2
front of vehicle
The coil pack is going to be hard to explain. The picture I'm looking at shows two bolt holes holding the coils on to the engine. Looking from the bolt hole side from left to right it is 1, 4, 6, 3, 2, 5
Wires
___________________
| O O O O O O |
| 1 4 6 3 2 5 |
|___________________|
|O| |O|
Bolts
Sorry about the crude picture, but it's the best I could do, and I couldn't cut and paste.
I hope this helps, and if you have any other questions, let me know. Also, this is NOT for the 3.8L V6. If that is what you have, let me know and I have to draw you another picture. (LOL)
Positive feedback is appreciated.
TXSLIM
Joe thank you very much for the info and drawing. It is a lot better drawing than the ones I have in 2 repair manuals I have, at least it is readable.
THANK YOU
kerry (AKA) txslim
  • 108,170 POSTS
Hi:
I'm glad it helps. Good luck, and if you have any other questions, let me know.
DOOGUMS
Electrical problem
1996 Chevy Lumina 6 cyl Two Wheel Drive Automatic
I need the plug wiring diagram and firing order also which ign coil services which plug
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_31_1.jpg
I found that in a database for the 3.1
firing order 123456
SERRANO4248
  • 1995 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 105 MILES
Firing order?
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_31firing_order_1.jpg
Monday, January 18th, 2021 AT 8:44 AM (Merged)
SHAWNLUX6
  • 1990 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 19,100 MILES
I need the firing order?
https://www.2carpros.com/forum/automotive_pictures/12900_fo_106.jpg
GIZMOGREER
  • CHEVROLET LUMINA
I am needing the Firing Order for a 3.1, 2001 Chevy Lunina, 126,000
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,882 POSTS
Here is a guide on how to change spark plugs for anyone that needs it.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Here is the firing order for you car
Firing Order 1-2-3-4-5-6
Check out the diagram (below)
Cheers, Ken
