Crankshaft angle sensor?
JOANNA0014
  • 1997 CHEVROLET LUMINA
  • 6 CYL
  • 159,000 MILES
Where is the crankshaft angle sensor at on 97 chevy lumina how to replace it?
Monday, December 27th, 2010 AT 7:55 PM
  • 108,170 POSTS
It is located in the center of the rear engine area and int he front depending on which style you have. It's below center exhaust port mounted in engine block. There is one screw that holds it in place. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Tuesday, January 18th, 2011 AT 7:00 PM
SHERRYODOM
  • 3.1L
  • 6 CYL
  • 150,000 MILES
My car started running bad, stalling at low speed. Tested with a diagnostic tester. Code said it was the crankshaft position sensor.
Saturday, October 10th, 2020 AT 9:21 AM (Merged)
HMAC300
  • 48,601 POSTS
They can go bad so replace it and see if it makes a difference. If it continues try cleaning throttle plate on both sides and IAC hole with choke cleaner. It just has one bolt and an electrical connection may be hard to reach however as it is by the transmission.
CAROLC1165
  • 1996 CHEVROLET LUMINA
Electrical problem
1996 Chevy Lumina 6 cyl Front Wheel Drive Automatic
I am trying to start my car it tries to start but it just cranks I just changed the ignition module and still doesnt start, it is getting fuel I checked that, it's pulsing, but no spark, we try to crank it, how can I take out the crank senson it's a lumina 3.1 1996
BLACKOP555
  • 10,371 POSTS
If your getting injector pulse then the crank sensor should be good. I would suspect bad ignition module, coil signal wire to the coil. Icm wiring harness.
SUPERSENIOR2008
  • 1992 CHEVROLET LUMINA
  • 6 CYL
  • 10,000 MILES
Where is the crank sensor on a 3.1 motor? On what part of the motor is it located or is it behind some part of the motor? Please help me!
  • 108,170 POSTS
On your 1992 Chevrolet Lumina-Sedan/Coupe 3.1L MFI OHV, the crankshaft position sensor is located: Under hood, passenger side, lower engine area, passenger side of engine block, mounted front of crankshaft pulley. Here is a guide to show you what you are in for when changing the sensor out and diagrams to show you what it will be like on your car below.
Cheers
KIRKBALL
  • 4 CYL
  • 170,000 MILES
How do I replace the crank position sensor without removing the intake manifold? The sensor appears to have no easy access for replacing.
Monday, October 12th, 2020 AT 11:23 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Here is a guide to show you what you are in for when doing the job and the location for where is is on your car below:
The sensor in under the ignition coil.
Cheers
TINKERGIRL
  • 17 POSTS
  • 1990 CHEVROLET LUMINA
  • 68,000 MILES
I have tried locating it with different repair manuals and databases and nothing tells me where the sensor is located. Please help!
Monday, October 12th, 2020 AT 11:24 AM (Merged)
HMAC300
  • 48,601 POSTS
It is on the lower rear right of engine by the oil pan. If you look from above the transmission and shine a light down there you will see the wires going to it. Not very easy to get to.
  • 108,170 POSTS
Under hood, center, rear engine area, passenger side of exhaust pipe, above oil pan, mounted in engine block.
JDL
  • 16,098 POSTS
I agree, not very easy. Safely raise and support the vehicle, so you can get at it. Even after you remove the hold-down bolt, may be very stubborn. If that is the original sensor, that flange is very thin and very brittle. Use a long shank screwdriver, after you remove hold down bolt and electrical connector. Place the tip of screwdriver in sensor electrical socket, push up, as hard as you can. If the sensor pops up a little, you can probably remove the rest of way with your hand. Maybe you will get lucky and it will be easy to remove. I usually do not get that lucky.
DAG2012
My mother's 1990 Lumina Sedan suddenly refused to start the after she had ridden it the day before without any issues for years. Last time it had a problem was when it suddenly quit running about twelve years ago and I believe the mechanic said it was the CPS (Crankshaft Position Sensor). If I remember right he said he bypassed it so that it would never cause any future issues. And whatever he did worked well for years, I have a few questions, is bypassing the CPS possible? After trouble shooting this car now for the last ten days, we eliminated fuses and such and to me it looked like it could be possibly the Ignition Control Module (ICM) or the Electronic Control Module (ECM/PCM). Took it in to a garage and after their analysis they said it was probably all three. I said that is impossible for all three to bad at the same time. So they convince me to replace the least expensive part, the CPS. If fact they said there are two CPS's in the Lumina one in the oil pan and one outside (I do not believe there is two). Anyway silly me agreed to let them change the outside one which is the only one I am aware of. Needless to say once replaced the car still did not start (still has no spark at the coming of the spark plugs). So now they thinking to replace the IGM, then next possibly the ECM. I am reluctant to give them the okay to replaced these in fear that the bill mounting up and there is no guarantee that after all three parts are replaced that the car will start. My initial thoughts was that the ICM had gone, only wished that they had started there first. Any opinions?
TINKERGIRL
  • 17 POSTS
If there is no spark it is either your brain (ECM) or the Igniter (ICM). This is just from what I have learned. I am no expert. All my problems after replacing the ECM had to do with the fuel system. I replaced all the injectors and the fuel pressure regulator. I hope that this helps. However, your best bet is to post the free question to the mechanic's forum yourself and they will assist you more. Good Luck!
JDL
  • 16,098 POSTS
Dag, I do not know how the mechanic would bypass the crank sensor?
COREY VEAL
Engine Performance problem
1990 Chevy Lumina 6 cyl Front Wheel Drive Automatic
Where is the crankshaft located on a 1990 Chevy lumina 3.1 V6
http://www.2carpros.com/forum/automotive_pictures/256068_100_0771_1.jpg
engine?
DNAPRORACING
  • 120 POSTS
On your 1990 Chevrolet Lumina-Sedan/Coupe (3.1L MFI OHV), the Crankshaft Position Sensor is located:
REDNECK1439
my car is running like it is burping. I replace the crankshaft sensor because it quit running. It has don this before. It started and I drove it less than a mile and it wont start. What would you suggest?
Monday, October 12th, 2020 AT 11:25 AM (Merged)
JDL
  • 16,098 POSTS
Welcome to the forum. How long since a tune-up? If it cranks good but won't start, I'd have a helper crank it, while I check for spark at the plugs. If spark everywhere, I'd use a gage and check fuel pressure. I'd also check for mil codes. To check for trouble codes, place a jumper wire between the A & B terminals at the datalink connector, turn the key till the dash lites come on, no further. The mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes. That picture below is a generic GM obd1 datalink connector.
https://www.2carpros.com/forum/automotive_pictures/170934_obd_1_datalink_connector_2.jpg
