Warning! Contour owners. Overheating
CLC361
  • CHEVROLET IMPALA
Many Contours have plastic impellers in the water pumps. They tend to break off and fall to the bottom of the fuel pump. You will quickly overheat and many mechanics will be puzzled. This tends to happen at 30-50K. Pumps are about $75-100 and the all metal ones only a few dollars more then the plastic ones. Thanks Ford for the great money saving part you came up with.
Do you
have the same problem?
Thursday, February 9th, 2006 AT 8:59 PM
JACK42
Good Info
Friday, February 10th, 2006 AT 5:06 PM
Recommended Guides
