Low compression Infiniti Q45 only one cylinder
ANJAVILO
  • 1945 CHEVROLET IMPALA
I find a leakage, the gasoline by pass the injector in to the admision port. A lot of gas within control.
smoke in the tail pipe.
Compression in all cylinder 220 psi
Compression in the afected cylinder 110 psi
Wet compression test 170 psi
What you do think
Do you
have the same problem?
Saturday, January 21st, 2006 AT 1:18 PM
JACK42
Gas washed rings
Friday, February 3rd, 2006 AT 3:46 PM
Recommended Guides
