Electrical
KODUS
  • CHEVROLET IMPALA
I have a '91 XJ6. I went to the car the other morning and the 'key in ignition' buzzer was sounding although the key was not in the ignition. Car starts and runs fine but the buzzer will not shut off. Even with no key in or the door closed. Will only shut off if I pull the 'ignition on' fuse. Turn signals, hazards, interior light, and raido ant. Do not operate. All other elec. Seems to be fine. Checked all fuses, all are fine. Am wondering if there is a relay that would control all these items or if a faulty ignition tumbler could be the cause? I have subsequently unplugged the ignition horn so that it won't drain the battery.
Thanks.
Do you
have the same problem?
Wednesday, January 4th, 2006 AT 3:21 PM
JACK42
Could be the tumbler
Wednesday, January 18th, 2006 AT 5:23 PM
Recommended Guides
