Car running hot
JAGERALDS86
  • 2008 CHEVROLET IMPALA
  • 3.5L
  • 6 CYL
  • FWD
  • 210,000 MILES
I have replaced the water pump, the thermostat, the coolant and did not see any leaks. But when my car got really hot I saw coolant pouring from the bottom of the radiator where I drained it
Wednesday, December 16th, 2015 AT 2:30 PM
HMAC300
  • 48,601 POSTS
Did you close the petcock ? if not it may have broken recheck your work.
These guides can help us fix it
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Wednesday, December 16th, 2015 AT 3:05 PM
JAGERALDS86
I made sure I closed it before refilling. It started draining when my car got really hot but before that nothing was leaking.
Wednesday, December 16th, 2015 AT 3:15 PM
HMAC300
  • 48,601 POSTS
Check around there for cracks or breakage they are only plastic tanks with aluminum fins so it may have cracked either at the petcock or lower rad hose if you took it off there. We have no pics of that so we can't send anything like that to you. It may also be a loose hose at pump and leaking down so check there as well.
Wednesday, December 16th, 2015 AT 3:43 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 2007 CHEVROLET IMPALA
  • 156,000 MILES
My car is making bubbling noises like its running hot but it's not reading hot inside nor do the fan come on
Monday, April 27th, 2020 AT 12:45 PM (Merged)
CARADIODOC
  • 33,741 POSTS
If you're hearing that under the hood, look for bubbles in the coolant reservoir. If you see them there, suspect a leaking head gasket. The clue, as you mentioned already is there's no steam associated with those bubbles.
JANETCHARITY2009
  • 2005 CHEVROLET IMPALA
  • 6 CYL
  • 4WD
  • 108,000 MILES
What causes a car to run hot? I tried a new thermostat but that not the problem.
Are you actually overheating or boiling over if not could be the gauge or the coolant temperature sensor misleading you-If not could be air in the system, clogged radiator or a malfunctioning water pump
KEAIRA02
  • 6 CYL
  • 4WD
  • 214,000 MILES
Ok, heres the deal. I have only had the car for a little over six months and got it from a used car dealership. The past two months I have been getting something done on this car and now Im starting to get frustrated. I have had a new thermostat put in and also had it boiled. Then I had the water pump checked and it is fine. They also checked the radiator and said it was fine as well. But yet the car continues to over heat. If I dont drive it for a week or so the first day it is fine and then after that it starts run hot and the light comes on and never goes off. Someone told me that it could be a problem in my engine. I am a female and lord knows I am past clueless in this matter. Can someone please tell me what it could be?
Monday, April 27th, 2020 AT 12:46 PM (Merged)
Could be airlock in the cooling system try getting it bleed don't work its time to get it block and pressure tested.
CLOROX.BLEACH
  • 17 POSTS
  • 2004 CHEVROLET IMPALA
  • 207,500 MILES
I am having a problem with my engine running hot. It runs fine when I have on the heat, but when I turn on the AC or ride without the AC, the temperature hand moves from normal operating temperature (half way mark) all the way over to the three quarters mark on the temperature gauge. It has never passed that point. It will get there, then it will slowly fall back to normal operating temperature, and then rises again. I am not losing any coolant and I am unsure of what could be causing this. I asked two repair shops and one person told me that it was normal for my car and engine to do that and the other repair shop told me that it was nothing to worry about altogether. I am unsure of what to think because I never had a car that runs hot like this.
  • 108,179 POSTS
If you feel it is raising to a point of concern and it has not done it before, there is a problem.
The fact that it lowers with the heater on is not uncommon. The heater core acts as an additional (small) radiator where coolant has extra time to cool.
On the other hand, the AC places an extra load on the engine that can cause it to run hotter.
Now, if the car only heats up when you are at a stop, make sure the cooling fans are running (when the gauge shows hot). If they are not, they need to. When the car is sitting, there is no air flow through the radiator to cool the coolant. As a result, the fans draw the air through it to keep it cool. When you drive, air flows. Therefore, if it is heating up while you are moving, I would suggest replacing the thermostat. It is a cheap part to start with and if it is sticking, it could be causing the problem as well.
If you want, we have a "how to" for checking the thermostat on our homepage under the DIY section. The hardest part is removing it. However, I would just replace it if I remove it. They are like $5.00.
Let me know if this answers your question and helps. If you have other questions, let me know.
CLOROX.BLEACH
  • 17 POSTS
My coolant fans are running and I have had them checked before. The radiator is also full to the top with coolant as well. I will try to replace the thermostat and see if that resolves anything. I have one more question though, would driving the car while it is hot affect anything? Like I stated before, the temperature hand rises and falls but never overheats.
  • 108,179 POSTS
You do not want the engine to overheat. If it does, it can cause other problems such as a blown head gasket, warped head. Because I am not there, I truly do not know how hot it is getting which makes it hard for me. Regardless, chances are it will continue to get worse over time. I would first start with the thermostat. Also, since you have to drain the radiator regardless, go to the parts store and get yourself a good radiator flush and flush it. That way you can get two jobs done in one and not have to re-drain the radiator if the thermostat does not fix the issue.
Hope this helps.
CLOROX.BLEACH
  • 17 POSTS
I have had my thermostat changed and the radiator flushed out and added new coolant to the system. It still is doing the same thing. I took it to multiple shops and I continue to get mixed answers. I am unsure of what to do next. I do not have any leaks and everything seems to be working fine, but the temperature hand still rises above normal operating temperature and occasionally falls down back to normal operating temperature.
CLOROX.BLEACH
  • 17 POSTS
I have also noticed a sharp drop in fuel economy, and the transmission starts shifting harder when it is hotter than it is supposed to be.
  • 108,179 POSTS
Can you tell me what they have checked so far?
CLOROX.BLEACH
  • 17 POSTS
So far I have gotten my spark plugs changed, my coolant system flushed, and a new thermostat. Everything else seems to be in working order says the people I took it to.
CLOROX.BLEACH
  • 17 POSTS
My temperature stays within this range. It does not go over that line, but it gets there and falls back and rises up again.
CADIEMAN
  • 3,544 POSTS
When it goes to 3/4 the fans come on and it drops to 1/2. If you were overheating you would know. A restricted radiator can cause this or a faulty coolant temperature sensor. Thank you for using 2CarPros.
  • 108,179 POSTS
If everything is good with the cooling system, the only thing I can think of is a bad temperature sending unit. That is what sends the signal to the gauge. However, I cannot understand why it would do what you described unless there is a resistance problem within the switch itself.
