Misfiring
PFORD79
  • 2000 CHEVROLET IMPALA
  • 6 CYL
  • FWD
I have a 2000 Impala 3.4L V6. At 45 mph to about 50 mph it will act like it's misfiring but the motor sounds fine. It doesn't do this with the cruise control on. Could it be something with the transmission or the throttle cable itself?
Monday, June 13th, 2011 AT 7:19 PM
Is the CEL/SES coming on and when was last tune-up??
Transmission could be slipping -check fluid level and condition if okay-check fuel pressure and also test the MAP and TPS sensors-crankshaft positioning sensor
Monday, June 13th, 2011 AT 7:36 PM
DONALD40033
  • 3.4L
  • 6 CYL
  • FWD
  • 167,809 MILES
I have a 2000 Chevy impala 3.4 it will misfire but not all the time.
Monday, March 13th, 2017 AT 3:34 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
Have the computer codes read and they should help pinpoint which cylinders.
MPOL
2000 chev impala started missing at any speed or rpm. Drove it several times during the day and when I came out of the store it was missing badly. Any ideas
SERVICE WRITER
  • 9,123 POSTS
A good spot to start is by pulling the codes from the computer.
https://www.2carpros.com/forum/automotive_pictures/30961_note_26.jpg
POCAHONTAS-2325
  • 2001 CHEVROLET IMPALA
I went to my mechanic today and they only had time to do a basic code retreival, but basically my 01 impala LS, 3800 v-6 series II, 121,000 miles, all four cylinders are misfiring at different times, but no. 4 is really bad. It only runs funny when I am accelerating, they said it could be as simple as spark plugs, but as serious as intake manifold. He indicated he was leaning toward ignition, or a coil going bad. Any thoughts or extra insight for me before I take it in tomorrow? It ran fine before yesterday morning.
CHEVY22
  • 1,375 POSTS
Na your guy sounds like hes on the money, always use delco plugs when tuning, and you may find a bad wire or corroded coil,
good luck
jim
TROYUS DALLAS
  • 2002 CHEVROLET IMPALA
My 2002 impala starts to skip
Do you have a check engine light and when was last tune-up?
Sounds like mifires-
Go to this link for more information: https://www.2carpros.com/articles/engine-misfires-or-runs-rough
2002IMPALALS
Recently my Impala started losing power when RPMs get around 4000. The first time it happened the check engine light flashed on/off, which the user manual stated as misfiring. The engine would not rev past 4K and pushing the pedal down further had no effect. The light only flashed and did not stay on after RPM's dropped below 4K. A computer scan showed no codes.
It still is happening, only when above 4K RPM, but the light no longer flashes. Below 4K the car drives fine. Still no codes in the computer and the light is still off.
Recently I put a bottle of Regane injector cleaner in the a full tank, and after that tank was empty refilled with 93 octane (typically I use 87-89 octane gas). I'm not 100% sure the problem started after this but it's probable because I never noticed it before the cleaner.
2002IMPALALS
If it helps anyone, the problem ended up being the catalytic converter. According to the mechanic, there was a stored misfire code in the computer, and when the engine misfired it was probably running on too rich a fuel mixture (possibly caused by the injector cleaner?), Which fouled the catalyst.
Luckily, this was covered under the EPA emissions warranty (8 years/80k miles), so I didn't have to pay for it. :)
