2002 Chevy Impala Brakes 'sink'
JDAVIS829
  • 2002 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 31,000 MILES
My brakes grab and hold. And then sink and give. And grab again. This doesn't happen every time I brake, but it's becoming more frequent. It's frightening, because the car moves forward after I've stopped. I passed inspection last week, so nothing was seen there.
Thanks for any help.
Do you
have the same problem?
Tuesday, June 16th, 2009 AT 9:15 AM
TAKECHARGESARGE
A brake pedal that tends to "sink" away from your foot after you have stopped and are sitting with your foot still on the pedal is probably a Brake Master Cylinder leaking the fluid past the internal o'rings. It won't show as a leaking fluid so it could possibly pass an inspection.
Replacing the Master Cylinder should cure the problem.
Good luck.
TakeChargeSarge
Monday, July 13th, 2009 AT 12:58 AM
