What are each wire color for the headlight wire harness? Trying to wire new DRL's
ASSCHADDER
  • 2004 CHEVROLET IMPALA
  • 85,000 MILES
Looking for description of each wire located in the headlight wire harness. What color are the turn signal wires? Your last answer helped alot, thanks.
Tuesday, September 20th, 2011 AT 3:01 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
Here are the full headlight and blinker wiring diagrams in the images BELOW. Left front turn signal wire is light blue. Left rear turn signal wire is yellow. Right front turn signal wire is dark blue. Right rear turn signal wire is dark green. Grounds are black. Common power for tail and license plate lights is black and white. Common power for front parking lights is yellow. High beams are pink wires. Low beams are dark blue. Ground is going to be black. Check out the headlight and DRL wiring diagrams (BELOW). Best, Ken
Wednesday, December 14th, 2016 AT 11:49 AM
JUSTIN1988
  • 2001 CHEVROLET IMPALA
  • 3.8L
  • V6
  • FWD
  • 107,000 MILES
When the car is off the LED and Halo lights are still on. I was wondering what wiring do I connect to so they will shut off when car is turned off?
Friday, November 9th, 2018 AT 8:12 AM (Merged)
CARADIODOC
  • 33,738 POSTS
That has to be some kind of aftermarket modification. The person who installed the lights connected them to the wrong circuits. Where the wires should be connected depends on when you want the lights to turn on.
CAR_MENDOZA_1984
  • 5 POSTS
  • 6 CYL
  • FWD
  • 75,000 MILES
I have an 04 impala ls 75000 miles I cant figure out whats going on with my headlight. The right ones work great but the ones on the left are dim. I tryed changing the bulbs nothing. They were fine and two days ago while I was driving it said highbeams out so I thought I just needed to replace them but their still dim. Any ideas?
SATURNTECH9
  • 30,870 POSTS
So is your low or high beam dim or are both of them dim?
CAR_MENDOZA_1984
  • 5 POSTS
The both are. Like really really dim
SATURNTECH9
  • 30,870 POSTS
Let's try this turn on the head light's on low beam then go to the dim side unplug the low beam bulb. Check and see if you have battery voltage to the orange wire. Then see if you have less then 2 ohm's to ground to the dark blue wire. Let me know what you find.
CAR_MENDOZA_1984
  • 5 POSTS
Sorry I took a while to answer but how do I check them?
SATURNTECH9
  • 30,870 POSTS
So both your high beam and low beam are dim on the left?If so I told you on the my last post how to test the low beam side. Here is what I said in my last post.
CAR_MENDOZA_1984
  • 5 POSTS
Yeah but how do I check the voltage?
TSF_92
  • 5 POSTS
  • 6 CYL
  • FWD
  • 113,000 MILES
I've been have problems with my tail lights and head lights not working. People on here said it could be my head light switch so I replaced that and they still don't work. Some on said on here that it could be the BCM. What is the BCM?
DOCFIXIT
  • 18,828 POSTS
Body Control Module located on left kick panel near park brake. Controls many functions including headlights
SATURNTECH9
  • 30,870 POSTS
You would check the voltage with a multimeter set to dc voltage 20 volt setting. The black lead to ground the red lead to the orange wire. You would use the same multimeter set to the 200 ohms scale the black wire to a good ground and and the red wire to dark blue wire and your looking for a reading of 2 ohms or less.
CAR_MENDOZA_1984
  • 5 POSTS
Ok ill let you know thanks
GBUHLER
  • 6 CYL
  • FWD
  • 150,000 MILES
The dim lights on my 2004 chev. Impala will not turn on. The daytime driving lights work, however as soon as the sun goes down they turn off, as they should, and the dim lights will not turn on automatically or with the switch. The brignt lights work fine. I have checked the bulbs and the relay.
KHLOW2008
  • 41,815 POSTS
System is equipped with self diagnostics and if there are trouble codes, a scan would assist in getting to the bottom of the problem.
The chart shows the diagnostic procedures.
Friday, November 9th, 2018 AT 8:13 AM (Merged)
2CP-ARCHIVES
  • 4,542 POSTS
  • 120,000 MILES
My front headlights are acting up. All 4 beams are on at one time. The left one's work as they should, and the right are both always dim, and when low beam is on, the high beam of the left is dim, and vice versa. Its none of the fuses, it's not the bulbs. I got it down to the grounds. But Where do I find the ground for the headlight?
JDL
  • 16,098 POSTS
Check for applicable troubles codes. There are lighting trouble codes. If your going to work on your own vehicles, at the least, you need an obd2 code reader that will read manufacturer specific codes as well as po codes.
Take the lamp connector loose, with headlamps on, check for the same voltage on all head lamp circuits, use chassis ground not headlamp connector ground.
In the diagram, the top wires are voltage, bottom wires are ground. The dimmer switch is part of the ground circuit, if you wan t to word it that way. The low beams ground through the headlamp relay in diagram. The high beams ground through dimmer switch ground. The ground wire location is the same for high and low.
Sorry it took so long.
WILLIAM E HENDRICKSON
Electrical problem
2004 Chevy Impala 6 cyl Front Wheel Drive Automatic
While driving at night my headlights go out when I switch from bright to dim. They return when I switch again to bright. I'm driving with my bright lights against oncoming traffic. I don't mind paying to have it repaired if it is truly something that I can't fix myself (replacing a relay or fuse), but I hate to take it into the shop where they charge me $50 to put it on their diagnostic machine while they go on a fishing expedition to find out what all they can scare me into repairing.
RHALL77
  • 3,361 POSTS
Sounds like a multi function swith. You need to remove the air bag to get at it. I would suggest having a professional do it
