Location of oil sending unit/do starter need to be removed to replace it? Please help I love this site.
Wednesday, June 10th, 2015 AT 4:51 PM
HMAC300
MECHANIC
Hello
The starter does not need to be removed. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Image (Click to make bigger)
SPONSORED LINKS
Thursday, June 11th, 2015 AT 5:59 AM
022750EW
MEMBER
1 POST
2005 CHEVROLET IMPALA
6 CYL
Where is the oil pressure switch located on a 2005 chevy impala 3.4?
Saturday, October 27th, 2018 AT 7:46 PM
(Merged)
DOCFIXIT
MECHANIC
The oil pressure sensor is on the lower left side engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
(Merged)
MRHAGBERG
MEMBER
2007 CHEVROLET IMPALA
6 CYL
2WD
AUTOMATIC
150,752 MILES
Where is the oil sensor located on a 2007 chevy impala ltz 3.9?
(Merged)
MECHANIC
Engine Oil Pressure (EOP) Sensor (3.5L, 3.9L) Right of starter.
SPONSORED LINKS
(Merged)
MRHAGBERG
MEMBER
Thank you for the information. I have 3.9 liter motor in the picture shows the 3.5 liter. On my motor there is a heat shield where it would appear that the oil filter would be in the illustration. Do I have to remove the heat shield to get at the oil sensor? Is there anything beyond that I need to beware of?
Thank you get your help
(Merged)
CASSIE88
MEMBER
1 POST
V8
FWD
AUTOMATIC
60,000 MILES
Where is the oil pressure sensor in a 07 chevy impala ss?
If necessary, remove the engine sight shield. Refer to Upper Intake Manifold Sight Shield Replacement.
Disconnect the oil pressure sensor electrical connector (4).
Using J 41712, remove the oil pressure sensor (706) and washer (707).
Images (Click to make bigger)
(Merged)
2CP-ARCHIVES
MEMBER
2006 CHEVROLET IMPALA
165,000 MILES
What is the location of the Oil Pressure sending unit
(Merged)
MECHANIC
Just above the oil filter.
It is a general answer since you provided no engine size
(Merged)
MAXANDMICKEY
MEMBER
1 POST
3.5L
6 CYL
FWD
AUTOMATIC
Could you please tell me the location of the oil pressure sensor on a 2007 impala 6cyl flex fuel 3.5 thank you
(Merged)
HMAC300
MECHANIC
See pic its by oil filter
SPONSORED LINKS
(Merged)
TWIN87
MEMBER
1 POST
2002 CHEVROLET IMPALA
V8
FWD
AUTOMATIC
157,812 MILES
Where is the oil sending unit located on a chevy impala
(Merged)
JDL
MECHANIC
Hello, it appears to be located above the starter.
(Merged)
TPENN12
MEMBER
1 POST
101,000 MILES
Can you email me an accurate diagram of the oil pressure sensor location on a 2007 chevrolet impala with the 3.9L engine or, at least provide some direction on how to locate? Some illustrations show it on the right side of the top manifold other info I've gotten says it could be located at the bottom of the engine near the oil filter.
(Merged)
CJ MEDEVAC
MECHANIC
. DIS WHAT YOU NEED?
THE MEDIC
(Merged)
LAURALEEWALKER
MEMBER
1 POST
V8
Where is oil pressure sending unit located on 2006 impala
