2000 Impala dasboard lights
IGGLES2001
  • 2000 CHEVROLET IMPALA
2000 Chevy Impala LS 84k
Dashboard lights do not work and I was told this morning that my running lights in the back are not working either. The turn signals, brakes, and hazards do light up when activated.
I had to get the drivers' side window motor replaced recently so I don't know if it is related but after that I noticed that when it is dark out my dashboard lights do not work and I can't see the radio, clock, or speedometer. When it is sunny out I can see that the radio is illuminated. Also, the headlight lever has 3 postions and when I used to put it in the middle postion the headlights would turn off if the car was in park but would come on when the car went into drive. Nowadays when it is in the middle postion the headlights stay off even while I am driving.
Do you
have the same problem?
Tuesday, November 13th, 2007 AT 10:52 AM
DENNYP
  • EXPERT
Possible defective headlamp switch
Tuesday, November 13th, 2007 AT 6:47 PM
Recommended Guides
