2000 Chevy Impala relearn procedure key an tumbler
JAMES BRAY1
  • 2000 CHEVROLET IMPALA
Electrical problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic
replaced the key an tumbler, now my car will not start. My old key would not turn anymore need 2 relearn soon please?
Do you
have the same problem?
Wednesday, August 12th, 2009 AT 6:28 PM
RACEFAN966
  • EXPERT
Ok here is what I found as to how to reprogram you key's. First turn switch to lock position. Now turn switch to start position and back to run (do not crank the engine), security light should come on for about 10 minutes, then turn key off when the security light goes off then turn key back to lock position. Repeat this two more times, then turn key back to lock position and then try to start it. It should start.
Thursday, August 13th, 2009 AT 11:35 AM
Recommended Guides
