Cigarette outlets have no power
RED247MAN
  • 2003 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 165,000 MILES
I have a 2003 chevy impala the cigarette outlets aren't getting power. I checked the connections behind the ash tray it's fine and I checked the fuse it looks good. How do I get power to my cigarette outlets
Wednesday, April 20th, 2011 AT 10:41 PM
JDL
  • 16,098 POSTS
There is a right I/P fuse 60 amp in the under hood fuse panel here is a guide to help you test it and the fuse location with the wiring diagrams so you can see how the system works.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Thursday, June 23rd, 2011 AT 8:02 PM
ENGLISHR
I have the same problem. The Aux light does not illuminate. I have no voltage at either the front console or rear console outlets. As illustrated in the schematic I found the 60 amp fuse was blown! Thanks for the post.
Tuesday, December 20th, 2011 AT 3:48 PM
JDL
  • 16,098 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Tuesday, December 20th, 2011 AT 4:55 PM
LITTLEJORR
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 175,000 MILES
My cigarette lighter contnues to blow fuses. I'll put a new one in and it will not blow until I put something (i.E. Phone charger, radar detector) into the socket and it gets moved. As long as it doesn't get bumped or moved in the socket it doesn't blow the fuse. Any suggestions? Where can I find a wiring diagram for the lighter? I have a book but it doesn't have that diagram.
Thursday, February 28th, 2019 AT 12:55 PM (Merged)
JDL
  • 16,098 POSTS
Welcome to the forum, my wiring info shows below picture. Maybe you need a new socket? My other suggestion is, don't bump it. lol
https://www.2carpros.com/forum/automotive_pictures/170934_cigar_liter_1.jpg
IAMYOURS
  • 2000 CHEVROLET IMPALA
Electrical problem
2000 Chevy Impala 6 cyl Four Wheel Drive Automatic
We got the battery replaced in april and before the battery was replaced the cigarette lighter worked but once the new battery was replaced it stoped working. We have checked all the cars fuses and there all good and we can figure out what would cause this. Can anyone help me out please.
RHALL77
  • 3,361 POSTS
Double check all your fuses. If they are ok, check for voltage at the connetor at the back of the socket. The housing for the lighter may have gone bad
IAMYOURS
I have even replaced the CIGARETTE LIGHTER and nothing worked
Thursday, February 28th, 2019 AT 12:56 PM (Merged)
RHALL77
  • 3,361 POSTS
But you need to check and see if the housing that hold the cig lighter is getting voltage. Did you check to see if there was voltage at the back of the connector
2CP-ARCHIVES
  • 4,542 POSTS
  • 2004 CHEVROLET IMPALA
  • 145,000 MILES
My cigarette lighter housing quit working and I need to know it I can get one at a auto parts store or does it take a special one?
  • 108,170 POSTS
You can get an aftermarket lighter, but I don't know what you mean about the housing quit.
TGREASHAM
  • 3.8L
  • 6 CYL
  • FWD
A penny dropped in my cigarette lighter I saw some sparks it didnt blow the fuse, I replaced the lighter but it still doesent work.
HMAC300
  • 48,601 POSTS
The fuse in in right dash fuse panel 15a should have been the one replaced. I tmay have burnt the element up so it may not work so test that with a light. There is also a 60 amp fuse underhood.
CCASTLEBERRY95
Electrical problem
2001 Chevy Impala 6 cyl Front Wheel Drive Automatic
A penny fell where my cigarette lighter goes and now it does not work.
DOCFIXIT
  • 18,828 POSTS
Has fuse been checked?
CCASTLEBERRY95
Yes checked the fuse
DOCFIXIT
  • 18,828 POSTS
Element most likely burnt out
AWTHACKER
Electrical problem
2000 Chevy Impala 6 cyl Two Wheel Drive Automatic
I dropped a dime inside the cigarette lighter. I jammed it down even further trying to get it out. Eventually I got it out, now the lighter doesn't work for charging or lighting. The fuse is not blown. Any help?
RHALL77
  • 3,361 POSTS
Double check all your fuses. You may need a new socket for the lighter if all the fuses are good.
DIANE BARRO
Electrical problem
2001 Chevy Impala 6 cyl Automatic 82000 miles
cigarette lighter won't work, can't charge cell phone, not the fuse.
