No Blower High Speed
JIMMIEZ
  • 2007 CHEVROLET HHR
  • 4 CYL
  • FWD
  • 88,300 MILES
A/C blower only blows low and intermediate speeds, not high speed. What is likely cause and repair/replace instructions.
Tuesday, October 18th, 2011 AT 6:09 PM
FIXITMR
  • 9,990 POSTS
Probably the switch itself. It connects different degrees of grounding to the blower. Take center panel apart(trim just pops off/out unscrew plate with switch) and unplug blower switch. Connect black and orange wires with jumper. This is HIGH connection to blower. If it works its the switch.
Tuesday, October 18th, 2011 AT 7:42 PM
FIXITMR
  • 9,990 POSTS
Here's a couple pics
Tuesday, October 18th, 2011 AT 8:02 PM
FIXITMR
  • 9,990 POSTS
If ya need a switch try ebay or salvage yard.
Tuesday, October 18th, 2011 AT 8:05 PM
BARBARA1963
  • 99 POSTS
  • 2006 CHEVROLET HHR
  • 2.4L
I have replaced the blower motor on this vehicle, checked all the fuses and replaced the hvac relay, I can hear the compresser but the blower seems to not be getting any power to it because I ran a straight wire and the blower worked, do you have any advice
Tuesday, July 9th, 2019 AT 11:39 AM (Merged)
HMAC300
  • 48,601 POSTS
Check bcm fuse 3 under hood it's a 30amp fuse then check to see if power is transferring through hvac relay or if relay is any good switch with a like relay. if still no power then have it scanned for codes. blower should work on high if resistor is bad resistor is by blower motor. this may be a body module as well as the blower goes through that. To be sure here is the blower wiring diagrams and a guide to check for power to confirm the failure.
VERNON NELSON
I had this problem and had to replace the HVAC controller cost me $254.00, all set. I love this site.
DECKHART
  • 4 CYL
  • FWD
  • 35,000 MILES
My heater and air conditioner fan only high speed and no lower speeds. What would be the cause and the fix?
DOCFIXIT
  • 18,828 POSTS
This sounds like you have a blower motor resistor that is out Here is a guide t help you get it replaced along with the diagrams of how the job is done on your car
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Cheers
SH7552
  • 4 CYL
  • FWD
  • 45,700 MILES
2006 chevy hhr. Fan motor for AC will not run.
WRENCHTECH
  • 20,757 POSTS
First check all the fuses and then try jumping power and ground directly to the motor to test it. If the motor is good, then determine if it's power or ground that it's lacking.
MEESPY
  • 4 CYL
  • FWD
  • 26,937 MILES
I have on several occasions had the blower fan kick on, sometime while, while the air or the heat is on, other times when its turned off, I have even had it go on, when the keys are not even in the ignigtion, and engine not running, can you explain this to me, its kinda creeepy when its happens, I just wonder how often it happens when the car is parked. It only runs for a few seconds and then quites, but sometime does it 3 or 4 times in a row. Seconds apart. No one seems to know why. Help.
Check if the blower motor relay is sticking
MEESPY
And where would I locate the blower motor relay switch?
Instead of the BMR check the HVAC relay in the body control module at no.30
https://www.2carpros.com/forum/automotive_pictures/12900_hvac_relay_1.jpg
