2001 Chevy Express Replacement spare
TBJR
  • 2001 CHEVROLET EXPRESS
  • 6 CYL
  • 95,000 MILES
Hi, i'm running a 2001 chevy express 3500. I need to find a replacement spare. I don't have much money to work with so i'm looking mostly on craigslist.
how compatible are rims from other vehicles? I've got 235/85/16 tires on the other four wheels. If I find a rim that will fit these tires will I be ok? Or do I need to find a rim specifically from a similar year express 3500?
so far i've got one reply offering a mid-80s early-90s suburban 8-lug with the right tire size for a good price. Should I go with this? Any questions I should ask?
Do you
have the same problem?
Monday, September 20th, 2010 AT 11:49 AM
OBXAUTOMEDIC
  • EXPERT
Thank You for the Donation.
Here is what you need to do.
Measure Center Hole size.
Measure Lug Hole - Center to Center Straight Across and from one to the next one center to center.
If all measurements match up you should be good to go.
Also is there a pic of the wheel? If so you can look at it and compare to yours.
Wednesday, September 22nd, 2010 AT 9:52 AM
Recommended Guides
