2005 Chevy Equinox ignition issue
CTALMAGE
  • 2005 CHEVROLET EQUINOX
  • 4 CYL
  • AWD
  • 85,000 MILES
Whenever I try to turn teh ignition key it will not turn. I have in the past tried to turn the wheel while turning the key at the same time and it would work now that is no longer working. Please help!
Thanks!
Do you
have the same problem?
Saturday, October 3rd, 2009 AT 3:03 PM
BRIAN 1
Check the ignition key, make sure it is not worn real bad, if it is replace the key, if it is not replace the ignition lock cylinder. Very common problem on these vehicles.
Tuesday, July 31st, 2018 AT 6:46 PM
