2005 Chevy Equinox engine light on
L. BRANDEN
  • 2005 CHEVROLET EQUINOX
  • 6 CYL
  • FWD
  • 116,000 MILES
The engine light just came on and I had a scanner hooked up and it registered code P0455. Evaporative emission control system leak detected. What is the most common failure that would cause this code?
L Branden
Do you
have the same problem?
Friday, June 18th, 2010 AT 8:21 PM
SATURNTECH9
  • EXPERT
If you clear the code doesn't it reset right away?
Friday, June 18th, 2010 AT 8:30 PM
Recommended Guides
