1999 Chevy Corvette
RUDYREYES
  • 1999 CHEVROLET CORVETTE
  • V8
  • MANUAL
  • 12,000 MILES
Category is not there to choose from
But what I got is the ac belt keeps jumping off track and I also noticed that my serpetine belt is also misaligned, I'm pretty sure that my crackshaft pully has moved forward about one inch, I can take a pry bar and move the pully towards the rear (when I have the belts off) but not quite lined up, and when I put my belts back on and start the car, the belts jump off alignment cause the pully moved forward again, is this something I can ajust or fix on my own?
How much work does this usually involve?
Do you
have the same problem?
Tuesday, August 5th, 2008 AT 9:54 AM
DOCFIXIT
  • EXPERT
Check to see crankshaft bolt is tight. No noises?
Tuesday, August 5th, 2008 AT 2:13 PM
Recommended Guides
