1995 Chevy Corsica Wiring harness from fuel injectors to fi
KARENSMAN
  • 1995 CHEVROLET CORSICA
  • 6 CYL
  • FWD
  • 164,000 MILES
I am having trouble with a wire that apparently keeps my car running. I have had to resolder the wires to my fuel injectors, and now one of the wires that connects to that is acting up. The harness that I am talking about splits into 3 or 4 different sections, and appears to go into the firewall on the passengers side. I have had to cut the wire, add more wire, and now I have new connector pins that do not fit the original pin housings, and I had to add a butt connector. I was running until I taped them up and put the wire tubing around them. Then it started stalling and running very rough. I am at my wits end on this one. Do I need to just get a new wiring harness, or is thi repairable?
Do you
have the same problem?
Thursday, March 4th, 2010 AT 7:50 PM
BIGJIM79
Yes definetly
Monday, March 29th, 2010 AT 11:26 PM
Recommended Guides
