1995 Chevy Corsica Water Leak
AMVARLADE
  • 1995 CHEVROLET CORSICA
Engine Cooling problem
1995 Chevy Corsica 4 cyl Front Wheel Drive Automatic
My 95 chevy corsica has a bad leak underneath the car causing it to overheat when I add water it just flows straight to out from the leak point. The leak is non pressure I can't figure out what is causing the leak could use some help thanks
Do you
have the same problem?
Sunday, March 15th, 2009 AT 6:21 PM
DOCFIXIT
  • EXPERT
Water pump
Monday, March 16th, 2009 AT 2:09 PM
Recommended Guides
