1989 Chevy Celebrity Engine Idle
VINCEATBOSCH
  • 1989 CHEVROLET CELEBRITY
  • 6 CYL
  • FWD
  • 256,000 MILES
This is a 2.8l Multi-Port Fuel Injected vehicle. My engine idle has recently increased to ~1000 RPM and will not decrease after the engine has warmed up. The Throttle position sensor voltage is 0.7V and the Idle Air Control resistance is 50 ohms on each coil. I have no Fault codes. Where else should I be looking for the cause of the high engine idle?
Do you
have the same problem?
Monday, June 8th, 2009 AT 1:12 PM
Try cleaning out the idle air control valve
Saturday, June 13th, 2009 AT 3:15 PM
Recommended Guides
