1989 Chevy Celebrity Car wont start
AMONTEZ
  • 1989 CHEVROLET CELEBRITY
  • 6 CYL
  • FWD
  • 501,357 MILES
My son and I left the house and when we pulled up to a stop sign the car stalled and hasnt started since. It will turn over but just wont start. Someone said to change the fuel filter so I did that and it started for a second but then started doing the same thing. Any help would be great.
Thanks.
Do you
have the same problem?
Monday, March 8th, 2010 AT 3:37 PM
JDL
  • EXPERT
How long since over-all tune-up? Use a gage and check fuel pressure. With an extended crank, visually check for spark at the plugs. Any trouble codes?
To check for spark at the plugs, you can pull a spark plug boot, stick known good plug or spark tester in the boot. Ground metal part of plug/tester to metal part of engine, with engine cranking, watch for spark.
Monday, March 8th, 2010 AT 3:56 PM
Recommended Guides
