Separate sensor for the fan relay
LIGHTEN
  • CHEVROLET CAVALIER
There is a separate sensor for the fan relay 2000 Cavalier where is it located
Do you
have the same problem?
Tuesday, September 18th, 2007 AT 12:41 AM
There's no other sensor than the CTS, its the computer called PCM that activates the fan relay you can see below -you're lucky am a nice guy. See below-Good Luck
http://www.2carpros.com/forum/automotive_pictures/12900_2000_cavalier_cooling_fan_circuit_1.jpg
Tuesday, September 18th, 2007 AT 4:37 AM
Recommended Guides
