Fuel pump replacement
BROAD
  • CHEVROLET CAVALIER
2000 chevy cavalier 130000 2.2l I need to replace the fuel pump in the car, is there an access panel in the bottom of the trunk under neith the spare tire?
Do you
have the same problem?
Tuesday, May 22nd, 2007 AT 2:28 PM
E40WATER12
No, the only way to change the pump u have to drop the support brackets, To fuel tank then remove the sending unit out, Then reinstall, then youre set
Wednesday, May 23rd, 2007 AT 2:37 AM
Recommended Guides
