87 Cavalier serpentine belt question
PAINTS4
  • 1987 CHEVROLET CAVALIER
I have an '87 cavalier with a 4 cyl. And the A/C compressor has locked up. Car starts fine when you remove the belt but will hardly even turn over because of bad A/C unit. If it was an older car with multiple belts I could just remove the A/C belt and be fine.
Can you use a belt for a non-A/C motor to bypass bad unit so car is still drivable, or do they use a completely different pulley set-up.
Do you
have the same problem?
Tuesday, August 21st, 2007 AT 10:52 PM
AMNORTO
Can you bypass the compressor with a shorter belt?
Wednesday, August 22nd, 2007 AT 12:23 AM
Recommended Guides
