2003 Chevy Cavalier speedometer
MIRABAGA
  • 2003 CHEVROLET CAVALIER
2003 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
my speedometer has been getting stuck while I drive. Anywhere from 5 miles over to going all the way around the speedometer. It use to fix itself within a day or 2, but now it's getting stuck and not moving on speeds. Please tell me what I need to do to get it fixed. Thanks!
Do you
have the same problem?
Thursday, January 14th, 2010 AT 1:15 PM
  • EXPERT
Is the needle actually getting stuck on something or just not working? If not working, check the vehicle speed sensor (VSS). If you can tell it is getting stuck on something, I have seen people take a very small drill bit, drill a small hole through the plastic cover and then use a thin wire to gently bend the needle away from the face of the panel.
Thursday, January 14th, 2010 AT 6:44 PM
Recommended Guides
