2002 Chevy Cavalier HARD TO START
TMMFLO
  • 2002 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 125,000 MILES
The car is hard to start, mostly when hot, but runs good when it finally starts, noticed gas in the oil.
Do you
have the same problem?
Wednesday, October 20th, 2010 AT 12:38 PM
JDL
  • EXPERT
I wouldn't drive it like that. Check the vac line for the pressure regulator, if you see gas, the regulator is faulty. Use a gage and check pressure, could be an injector leaking? Change the oil and filter, after you find the problem, you may have to change more than once?
Wednesday, October 20th, 2010 AT 3:04 PM
TMMFLO
JDL - right on the money, faulty pressure regulator.
Thank You,
TMMFLO
Tuesday, November 2nd, 2010 AT 7:28 PM
Recommended Guides
