2001 Chevy Cavalier Fuel pump
JOHNCAP69
  • 2001 CHEVROLET CAVALIER
2001 Chevy Cavalier
Why does my fuel punp keep going out?I've changed it several times now, and it only last, maybe 4 weeks, or less.
Do you
have the same problem?
Sunday, May 24th, 2009 AT 9:51 AM
JDL
  • EXPERT
Hello, are you using oem pumps or the cheapest you can find? I always use the cheapest, probably not the best. I'd check fuel pressure, check for good voltage and ground at the pump.
If you know the pump manufacturer, they usually have a web page and email address, send them an email about your problem. I talk to them every once in a while, they always respond.
Sunday, May 24th, 2009 AT 10:10 AM
Recommended Guides
